The fan speed is fixed to 4000 RPM, can this be changed to smart as the switch is not installed in a server cabinet. the tempeture is als stable. i think it should ajust itself according toe what th...
BrianL
Feb 04, 2024NETGEAR Moderator
Hi Dimitri_vanes,
A quite similar thread has been posted before (you can see it here). Let me check with our Switch Engineers if this feature request has been logged.
Kind regards,
