jeroendevos
Jul 05, 2020Follower
Feature Request M4300 Silent Fan Option
Feature Request,
i allready spoken to the support team of netgear if its possible to set the fan speed in the M4300 , this is because the switches are installed in a House,
Maybe anybody a solution of the developer team?
Kind Regards,
4 Comments
- DaneANETGEAR Employee Retired
Welcome to the community! :)
It seems you are referring to firmware v12.0.11.8 which includes a new feature/enhancement for the M4300-8X8F platform wherein the user can turn off the FAN to keep the device quiet. I believe you wanted to have the same feature/enhancement to be implemented on other M4300 series switch models which is why I moved your concern here in the Idea Exchange for Business board. In this way, the development team can see what feature does users wanted to be added to the functionality of the M4300 series switch models.
DaneA
NETGEAR Community Team
- jeroendevosFollower
Hello DaneA,
Yes thats Correct,
Kind Regards,
- meteFollower
Hello,
I wonder if there is any update on this particularly for 12x12F.
Mete
- AVITWLNovice
Can anyone advise if there was an update for this?
Looking to lower the speed of a Netgear GSM4352PB
