fallsfal
It appears no longer possible to configure ReadyNas to use Backblaze Amazon s3 backup per https://help.backblaze.com/hc/en-us/articles/1260804505130-How-to-use-Netgear-ReadyNAS-with-Backblaze-B2, I suspect that direct use of Amazon S3 fails as well but haven't tested that. I received this response from Backblaze support:
The requirement for V4 signatures is indeed a part of the S3 compatible API. The older versions have been deprecated and as a result, we have stopped supporting them. Unfortunately, I am not able to troubleshoot their device and it's utilities. I would recommend reaching out to their support to see if there is a way to update or alter the signature they are using. Apologies for not being able to be more help there.
7 Comments
- sapmecAspirant
FYI...I too am experiencing this issue and was directed to this section from the community support page.
- original community support post information:
- https://community.netgear.com/t5/ReadyNAS-Cloud-Storage/readynas-backblaze-b2-problem-connection/m-p/2188993/emcs_t/S2h8ZW1haWx8bWVudGlvbl9zdWJzY3JpcHRpb258S1lUOUc1UTEzRU5aNVh8MjE4ODk5M3xBVF9NRU5USU9OU3xoSw#M13127
- https://community.netgear.com/t5/ReadyNAS-Cloud-Storage/Rn21200-ReadyNAS-6-10-6-will-not-accept-my-Baclblaze-B2-S3/m-p/2174498#M13079
- my unit is a ReadyNAS 2430 with the latest firmware version Firmware = 6.10.6
- the S3 back-up was working fine a few months ago and then just stopped working and can no longer be set back up
- error message is as follows:
- 'Failed to list Amazon S3 buckets. Failed to list buckets. Code 37007000029'
- sapmecAspirant
FYI...latest ReadyNAS OS 6.10.7 still does not resolve the issue :-( on my ReadyNAS 2304
- bvbbvbGuide
Looks like we're being abandoned. I got this response from Netgear Support:
As per our Engineers, there is no plan of updating the signature since the [ReadyNAS] device is already an end of life unit. I will close this case now.
They did not respond to my followup as to which ReadyNAS online backup options are still functional.
- sapmecAspirant
bvbbvb well that's a big bummer, did they happen to mention if this issue will not be fixed for ALL ReadyNAS OS devices? Mine is an RR2304 which I do not believe is end of life (yet)...maybe it is though? Seems a little odd that they would not fix this for current ReadyNAS devices and this Cloud S3 back-up does not seem like it would be specific to hardware vs. OS software.
- bvbbvbGuide
There's some evidence (e.g. https://www.downloads.netgear.com/files/netgear/pdfs/EOL.pdf) that the entire ReadyNAS line is End of Life. Perhaps the rise of cloud computing has destroyed the commercial viability of in-house NAS solutions.
- sapmecAspirant
FYI...for what's it's worth I switched to using ChronoSync app locally on server that does a sync with target Backblaze service.
