Duncker-Munnikh
Jun 11, 2019Initiate
Status:
New Idea
Get rid of the JAVA Requirement for "Device view" in the Prosafe switches
Hi,
Having multiple M4100 and GSM7228 switches where device view is not working due to Java support in the webbrowser. Althought there should be a work arround with installing an old java and using IE11 this is not an ideal solution.
I had simular issue with HP 2910 switches, HP made a new Aruba firmware for this switch and is now fully web-managed.
I see a lot of people with the same issue in the ICT businnes with no proper solution. Spending € 1400 for a new switch which require an old Java is not done.
Kind regards,
Steven
No CommentsBe the first to comment
