Napsterbater
Apr 26, 2017Apprentice
GS724Tv4 IGMP Snooping on a VLAN breaks IPV6 Multicast on same VLAN, Still after over 1.5yrs.
The "workaround" about doing it at port level is not 100%, seems alot of Multicast stream are missed and not reported in the switch in that config. When setup at the VLAN level it works 100% like its...
Napsterbater
May 03, 2017Apprentice
Its not a "Feature Request" is a bug report/reminder, its broken. the "Feature" is there, but it breaks stuff.
I went back and forth with supprt/tech/engineers or who ever it was a year and a half ago. They reproduced the problem. They never Fixed it.
I recently found some traffic not getting caught by IGMP unless IGMP was enable for the VLAN, but If I do that I break IPv6 on that VLAN. So either I flood the switch with that traffic or I completely kill IPv6.
Again its broken, this is a Broken "Feature".
