I think it's completely ridiculous that Insight does not allow for more flexible SNMP configurations. I can go into Insight and set an "SNMP Trap" for a location, which actually sets SNMP. However, it only supports one, has arbitrary requirements on it (specific snmp community requirements, such as have a special character for one), doesn't let you use anything that is considered a network address for a /24 network (i.e, 10.0.1.0, which is a valid host address for 10.0.0.0/23), doesn't allow multiple community strings, etc.
Ideally, it should allow you to set things the same way as the local page for snmp, if I want to allow an entire subnet to be able to SNMP probe a device, I have to turn Insight off, configure SNMP, then turn Insight back on. The settings stay and continue working, so there's 0 reason they could not be applied directly via insight.
No CommentsBe the first to comment
