grandslam
Jun 18, 2019Follower
Status:
New Idea
Include PoE Fix of GS105PE 1.5.0.1 into the main stream releases.
After my own support case which resulted like many threads in the netgear community already mentioned.
The beta firmeware 1.5.0.1 fixes a PoE negotiation problem that never got into the main stream releases (now 1.6.0.4).
suggests to open a support case... reading all the community posts where some did that... it doesn't seem to help to fix this in an official release.
I was asked from the support agent to post it here to get this fix hopefully into the official releases.
Summary of the case:
GS105PE does not negotiate with PoE+ (at) with a switch that provides PoE+. It always falls back to "af".
There is a painfull workaround: Connect everything, switch negotiate at "af". Then just press the hard reset button for more than 10 seconds and the immediatly resets and negotiate at PoE+ (at).
There exists a magic beta firmware version 1.5.0.1 which can be requested by opening a support case. Which also immediatly negotiate at PoE+ (at) directly after flashing the firmware version.
No CommentsBe the first to comment
