MTAC's avatar
MTAC
Status:
New Idea
insight app
Hi
It's a bit confusing that in the Insight App I'm told that the BR200 Router is mentioned as a Insight Instant VPN or add to a router. But when I'm trying to create or add to a VPN group, It' doesn't support VPN. It seems like the BR500 is a far better product than the BR200.
1 Comment
  • schumaku's avatar
    schumaku
    Reads like the Insight cloud and/or the Insight App isn't properly adopted to the BR200 yet - features not available should not be visible.
    The BR200 and the BR500 are very similar - just the (in my opinion unlucky) cloud supported Instant VPN isn't part of the BR200 anymore.If the plan is to add more Instant VPN nodes to an Instant VPN environment, you need BR500, not BR200.
