JayC333's avatar
JayC333
Follower
Jan 19, 2025
Status:
New Idea
Insight Managed WiFi 7 Tri-band Access Point (WBE750) Web UI Configuration
Hi,
I've been testing WBE750 for a couple of weeks and a bit disappointed by the lack of WebUI Configuration options.
Would it be possible to add
1. A way to change the default port for HTTPS (from 443 to another port)
2. A way to change / update SSL certificate (ideally with a way to retrieve the certificate using acme or from a local repository)
Best regards
