- Please add a way on insight to see the device menu the same as the Local UI. It is frustrating to be comfortable in the local user interface and not be able to find a setting.
- DOS (denial of service) freaked out and shut down all of my ports. I had access to Insight but could not find any way to shut it down. If a security issue require a MFA prior to making the change.
- Search boxes? Mine do not work. It would be amazing to type DOS and have it take me to the menu for it.
- List of common settings for most devices that are factory preset, so you don't have to search for it and you know what it is set to.
No CommentsBe the first to comment
