wimcas's avatar
wimcas
Follower
Jun 11, 2020
Status:
New Idea
Intelligent scheduling GS110TP
Dear Netgear,
Can you make the scheduling of POE ports on the GS110TP more flexible? At this moment you can only use one plan, but what is you want to make it flexible?
Like you want to have different schedule times in week days and weekends, or a schedule that start 4 times a day?
I am used to the scheduling in my old Netgear R7000 router and this way way more advanced.
Things would be solved if you can choose more timer config per port. I think this is simple to inplement.
Thank you.
Wim
No CommentsBe the first to comment
