Shocklog's avatar
Shocklog
Initiate
Oct 26, 2016
IPV6 in load balancing mode on SRX5308
If you have more them one internet connect you cannot use IPV6, because IPV6 is only available in Primary WAN Mode. Also you lose all you’re settings when you change from Load Balancing to Primary WAN Mode or from Primary WAN to Load Balancing Mode, which is very frustrating.
2 Comments
  • JohnRo's avatar
    JohnRo
    NETGEAR Employee Retired
    Hello Shocklog,
    Welcome to the community!
    Your idea to improve the quality and functionality of the product is very much appreciated, we thank you for sharing and interest in this. Adding kudos to the ideas will help as development team will be reviewing the post that has the most kudos for considering it to add to the product's future functionality.
    Thanks,
  • Essentially if Netgear have no plans to implement IPV6 in Load Balancing mode on the SR5308, then organisations with more than 1 internet connection cannot use this product. Which is a shame because otherwise it is a very good reliable product?
