JustinTim's avatar
JustinTim
Follower
Jan 29, 2020
Status:
New Idea
L3 DHCP Relay for S3300 switch
Hi,
The lack of L3 DHCP Relay on the S3300 switch is quite problematic.
We're facing situations where a site is equipped with a router managed by third party.
Ideally, we would like to cable the site with only a stack of S3300 switches but since they do not support L3 DHCP Relay, we would also have to include a router or server handling either direct or relayed DHCP.
The S3300 can have a routing table, an L3 address and supports a default gateway..
Could the Netgear team look into adding the support for L3 DHCP Relay as well?
Thanks,
Justin
No CommentsBe the first to comment
