Open Side Menu
Skip to contentBrand Logo
COMMUNITY
MY NETGEAR
SUPPORT
KNOWLEDGE BASE
NETGEAR APPS
Chinese (Simplified)DutchEnglish (US)FrenchGermanItalianJapaneseSpanish
RegisterSign In
  1. NETGEAR Communities
  2. Welcome to the NETGEAR Community
  3. NETGEAR Enterprise
  4. Feature Requests
NETGEAR Community now requires you to sign in.
For support on NETGEAR Home and Mobile products please visit https://www.netgear.com/support/home/
fabriks's avatar
fabriks
Follower
Sep 29, 2019
Status:
New Idea
Link Aggregation for GS308E
Any chance that LAG will be available on the GS308E in future firmware updates?
Smart Managed Plus Switch
Smart Switch
NerdBit's avatar
NerdBit
schumaku my bad! apologies, didn't have any wrong intention to start an argument. It was my sheer frustration with false advertising of "product spec and definition process".
As a well-known and respected brand, it wouldn't hurt to look at the competition and reflect on how explicitly they make mention on their lower-mid-end switches supporting static aggregation only.
As I'm trying to get this set up for a volunteer-run not-for-profit company, the time, and troubleshooting it has taken has done my head in.
The goal was straightforward:
DIY Router/Firewall appliance ---> Setup LAGG on x2 ports ---- SWTCH ----> Access Point.
All works well from either end, except for the Link aggregation bit as the switch does not support LACP protocol.
Would you be willing to help in setting LAG correctly on this switch, suppose it would be Static Aggregation now. To be fair, there isn't much available option-wise in the GUI. Just LAG1 (Choose from 1,2,3,4 port) LAG2 (Choose from 5,6,7,8).
and a toggle bar to choose which one. In my case I had chosen LAG2 (Port 7 and Port 8 ) and toggled the little button to "green".
From your exp, is there anything I may have overlooked?
