Any chance that LAG will be available on the GS308E in future firmware updates?
24 Comments
- LAGG Protocol
The operating modes for LAGG interfaces are: LACP, Failover, Load Balance, Round Robin, and None.
- LACP
The most commonly used LAGG protocol. ---> borrowed this text from the pfsense software, derived from FreeBSD. in the Netgear plus switch context, only Load Balance and Round Robin are meaningful. LACP isn't available <---
- Failover
When using the Failover LAGG protocol traffic will only be sent on the primary interface of the group. If the primary interface fails, then traffic will use the next available interface.
Note
By default, traffic may only be received by the active interface. Create a system tunable for
net.link.lagg.failover_rx_all with a value of1 to allow traffic to be received on every member interface.Failover mode has one additional option:
- Failover Primary Interface
This option sets the primary interface for failover mode, or auto to allow the firewall to select the primary interface automatically. In auto mode, the first selected interface in the list is primary.
Each non-primary interface is eligible for use in failover if the primary fails.
- Load Balance
Load Balance mode accepts inbound traffic on any port of the LAGG group and balances outgoing traffic on any active ports in the LAGG group. It is a static setup that does not monitor the link state nor does it negotiate with the switch. Outbound traffic is load balanced based on all active ports in the LAGG using a hash computed using several factors, such as the source and destination IP address, MAC address, and VLAN tag.
- Round Robin
This mode accepts inbound traffic on any port of the LAGG group and sends outbound traffic using a round robin scheduling algorithm. Typically this means that traffic will be sent out in sequence, using each interface in the group in turn.
- None
This mode disables traffic on the LAGG interface without disabling the interface itself. The OS will still believe the interface is up and usable, but no traffic will be sent or received on the group.
- Description
A short note about the purpose of this LAGG instance.
LAGG Interface Configuration
To create or manage LAGG interfaces:
Navigate to Interfaces > Assignments, LAGGs tab
Click
Add to create a new LAGG, or click
to edit an existing instance.
Complete the settings as described in LAGG Interface Settings
Click Save
After creating a LAGG interface, it works like any other physical interface. Assign the lagg interface under Interfaces > Assignments and give it an IP address, or build other things on top of it such as VLANs.
Note
comstar_3068 SYN ACK - thank you for coming back to your previous comments
- scriptosNovice
I also came here after a long research and I am sad and disappointed at the same time. -.-
Looking into the refreshed GS308Ev4 model documentation does not shine more light - the same confusion as before remains. IphieChen Iphie_C YeZ
GS308Ev4 User Manual p.55 ff. does clearly refer to the ability for configuring to static LAG - just like the similar GS305EP, GS305EPP, GS308EP, GS308EPP
GS305E and GS308E Datasheet (D-GS305E/GS308E-24May24)
I won't buy any GS308Ev4 or GS305Ev4 just to find proof what (DS, UM, or the effective product) is wrong. This is what Netgear product managers are paid for 8-)
