25 Comments
  • schumaku's avatar
    schumaku
    LAGG Protocol
    The operating modes for LAGG interfaces are: LACP, Failover, Load Balance, Round Robin, and None.
    LACP
    The most commonly used LAGG protocol. ---> borrowed this text from the pfsense software, derived from FreeBSD. in the Netgear plus switch context, only Load Balance and Round Robin are meaningful. LACP isn't available <---
    Failover
    When using the Failover LAGG protocol traffic will only be sent on the primary interface of the group. If the primary interface fails, then traffic will use the next available interface.
    Note
    By default, traffic may only be received by the active interface. Create a system tunable for net.link.lagg.failover_rx_all with a value of 1 to allow traffic to be received on every member interface.
    Failover mode has one additional option:
    Failover Primary Interface
    This option sets the primary interface for failover mode, or auto to allow the firewall to select the primary interface automatically. In auto mode, the first selected interface in the list is primary.
    Each non-primary interface is eligible for use in failover if the primary fails.
    Load Balance
    Load Balance mode accepts inbound traffic on any port of the LAGG group and balances outgoing traffic on any active ports in the LAGG group. It is a static setup that does not monitor the link state nor does it negotiate with the switch. Outbound traffic is load balanced based on all active ports in the LAGG using a hash computed using several factors, such as the source and destination IP address, MAC address, and VLAN tag.
    Round Robin
    This mode accepts inbound traffic on any port of the LAGG group and sends outbound traffic using a round robin scheduling algorithm. Typically this means that traffic will be sent out in sequence, using each interface in the group in turn.
    None
    This mode disables traffic on the LAGG interface without disabling the interface itself. The OS will still believe the interface is up and usable, but no traffic will be sent or received on the group.
    Description
    A short note about the purpose of this LAGG instance.
    LAGG Interface Configuration
    To create or manage LAGG interfaces:
    • Navigate to Interfaces > Assignments, LAGGs tab
    • Click
       Add to create a new LAGG, or click
       to edit an existing instance.
    • Complete the settings as described in LAGG Interface Settings
    • Click Save
      After creating a LAGG interface, it works like any other physical interface. Assign the lagg interface under Interfaces > Assignments and give it an IP address, or build other things on top of it such as VLANs.
      Note
  • I also came here after a long research and I am sad and disappointed at the same time. -.-
  • schumaku's avatar
    schumaku
    Looking into the refreshed GS308Ev4 model documentation does not shine more light - the same confusion as before remains. IphieChen​ Iphie_C​ YeZ​
    GS308Ev4 User Manual p.55 ff. does clearly refer to the ability for configuring to static LAG - just like the similar GS305EP, GS305EPP, GS308EP, GS308EPP
    GS305E and GS308E Datasheet (D-GS305E/GS308E-24May24)
    I won't buy any GS308Ev4 or GS305Ev4 just to find proof what (DS, UM, or the effective product) is wrong. This is what Netgear product managers are paid for 8-)
  • FYI I did purchase a GS308Ev4 for other reasons but recently had a reason to look into LAGs support. Running firmware V1.0.1.13, looks like it is in fact an option in the web UI, but I won't be onsite for a bit to test.
