ALL FIRMWARE should be updated. More info: https://betanews.com/2017/10/16/krack-wpa2-security-vulnerability/
Galt
Dec 05, 2017Aspirant
Netgear has rolled out a patch for the ORBI system that patches the WPA2 KRACK vulnerability (V2.0.0.76). It will not show up as an online update, it must be installed manually. I uploaded the patch yesterday. For those with other routers, you may want to check, as it seems Netgear is finally getting these updates out to us.
https://kb.netgear.com/000049562/RBR50-RBS50-Firmware-Version-2-0-0-76-Hot-Fix
