Open Side Menu
Skip to contentBrand Logo
COMMUNITY
MY NETGEAR
SUPPORT
KNOWLEDGE BASE
NETGEAR APPS
Chinese (Simplified)DutchEnglish (US)FrenchGermanItalianJapaneseSpanish
RegisterSign In
  1. NETGEAR Communities
  2. Welcome to the NETGEAR Community
  3. NETGEAR Enterprise
  4. Feature Requests
NETGEAR Community now requires you to sign in.
For support on NETGEAR Home and Mobile products please visit https://www.netgear.com/support/home/
Auri's avatar
Auri
Star
Oct 16, 2017
Status:
New Idea
Patch for Krack Vulnerability
ALL FIRMWARE should be updated. More info: https://betanews.com/2017/10/16/krack-wpa2-security-vulnerability/
Firmware
Hack
Insight AP
krack
ORBI Pro
Security
SMB AP
vulnerability
wpa2
dww_3's avatar
dww_3
Onlooker
Dec 05, 2017
One more note on the release notes for the R7000 12/1/17 patch: The light will blink amber during an update, but should return to solid WHITE after the patch is complete, not solid amber as stated in the release notes.
  1. The upgrade process is completed when the on screen progress bar completes.
  2. If the upgrade progress bar on web GUI doesn’t display correctly during firmware upgrade, you can still check the status using Power LED. The Power LED should be blinking (amber) during firmware upgrade.  After firmware upgrade is done and boots up the system, it changes to steady AMBER color
  3. Please DO NOT power off or reboot the device during firmware upgrade, otherwise, it  may result to a corrupt firmware and cause the device not to work.
