Open Side Menu
Skip to contentBrand Logo
COMMUNITY
MY NETGEAR
SUPPORT
KNOWLEDGE BASE
NETGEAR APPS
Chinese (Simplified)DutchEnglish (US)FrenchGermanItalianJapaneseSpanish
RegisterSign In
  1. NETGEAR Communities
  2. Welcome to the NETGEAR Community
  3. NETGEAR Enterprise
  4. Feature Requests
NETGEAR Community now requires you to sign in.
For support on NETGEAR Home and Mobile products please visit https://www.netgear.com/support/home/
Auri's avatar
Auri
Star
Oct 16, 2017
Status:
New Idea
Patch for Krack Vulnerability
ALL FIRMWARE should be updated. More info: https://betanews.com/2017/10/16/krack-wpa2-security-vulnerability/
Firmware
Hack
Insight AP
krack
ORBI Pro
Security
SMB AP
vulnerability
wpa2
Charlie417's avatar
Charlie417
R7900 with firmware 1.0.3.8_10.0.37 will it fix KRACK I have a Netgear Nighthawk X6 R7900 router and am using firmware version 1.0.3.8_10.0.37 DOSES THIS VERSION OF FIRMWARE FIX THE PROBLEMS CREATED BY KRACK? If it does not fix KRACK what can I do to work around the problem? I have seen Security Advisory for WPA-2 Vulnerabilities PSV-2017-2826, PSV-2017-2836 https://kb.netgear.com/000049498/Security-Advisory-for-WPA-2-Vulnerabilities-PSV-2017-2826-PSV-2017-... The listings do not show R7900 I am using my router in BRIDGE MODE Is firmware V1.0.3.8_10.0.37 sufficient to solve the KRACK problem?
