I offer RBK 352 model to several businesses, and I need to manage it later after installation, but in the Orbi app, I can only mark it with the model name as in the picture. In situations where you h...
andrewpaulson
Jul 02, 2025Aspirant
- Go to the Orbi app
- Tap the device
- No rename option (just shows model)
- Would be great if we could tag them like “Client1_RBK352”
- andrewpaulsonJul 02, 2025Aspirant
Hope this issues solved by following above steps. also make sure that the orbi app you are using is properly isntalled on your device and completely working. Get this app from a safe appstore
