BGP4's avatar
BGP4
Follower
Mar 07, 2022
Status:
New Idea
Save Configuration from WebInterface "Are you sure?", Diff Config, Return to startup-config
Please add an Question "Are you sure?" to the WebInterface Save-Button.
Otherwise the "Exit/Logout" Button is far to near to Save.
Also add a return to startup config button and add a diff config button
2 Comments
  • schumaku's avatar
    schumaku
    Which Netgear switch product line, and even more the model line you are referring here? Consider to add some screenshots to your proposal to describe things better.
    The neither the tagged "Smart Managed Plus Switches" models nor the "Smart Managed Switches" product line models have a [Save] button to my knowledge. Web config changes are applied automatically to the running and startup config.
  • M4300 Series
    The Tag in this Community is buggy. If Choosing M4300-48X i cant select Full Managed!
