Hi, Using Insight we can do a speedtest to see how fast the connection is. I’m using a PR60X with a 4Gbps fibre connection but running speedtest from the router (both via Insight or the local GUI) ...
Music-IT
Feb 09, 2024Tutor
Hi schumaku, as far as I understand your French post after using the translator I see exactly the reason why I want control over te selection off the target Speedtest server. I have alway’s been using the same server what is stable and fast so I can compare lines. My line is 4Gbps and when testing it with computer directly connected to my router I get values near the 4Gbps but only with a few very specific servers. When I do the speedtest with auto selecting servers it will find servers closer to my place but they can’t handle the 4Gbps.
And as we don’t have control over the server selection when running the speedtest direct from the router using Insight or the router gui it might just select one of the non capable servers.
That is why I want control over the selection of the target server!
rgds
Rob
