The GS110TP supports only a max SSL key length of 2048 bits. This is a real problem for modern PKI infrastructures where - at least - the CAs almost always use a 4096 bit key length.
Given that...
schumaku
Mar 21, 2019Guru - Experienced User
This applies to all Smart Managed PRo switches still under maintenance and support.
