I want to make a time schedule for one POE port from 20:00 to 8:00 next day it should be disabled. This is now not possible. I have to make two schedules one from 20:00 to 23:59 and one from 0:00 to 8:00 but does not give the intende result since from 23:59 to 0:00 the port goes on. This because 24:00 is nota valid value and in fact it has to be valid.
Other option could be set with the schedule is the port has to switched of or on then the rule could be from 8:00 to 20:00 switch the port on other time switch it of . repeat this for every day.
2 Comments
- NieuwenborgFollower
Will netgear do something with this?
- AlexegNovice
I have the same issue and I like both suggestions.
