classicsound's avatar
classicsound
Follower
Oct 25, 2022
Status:
New Idea
User Management for AV Line
Hello,
I am just starting to work with the AV Line switches. I use them in a concert hall. There is an administrator and many users running the shows. For this, from my point of view, there needs to be some kind of user management. On the one hand, of course, the administrator with full access, but on the other hand, another account for status monitoring and assigning ports to VLANs, if that is necessary for a show.
A user management with rights management would be perfect for this.
Is such a feature already planned?
3 Comments
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    classicsound,
    Welcome to the community! 🙂
    The M4250 series switches which is the AV (Audio-Video) Line Managed Switches of NETGEAR supports Management VLAN.  By default the Management VLAN is VLAN 1 and you can change the Management VLAN to any VLAN you want.  Be informed that all switch features such as VLAN, ACL, QoS, etc can be configured using the Main local browser user interface (Main UI) or via the Command Line Interface (CLI).
    The M4250 series switches also have an Audio-video local browser user interface (AV UI) which is a web-based management tool that lets you configure and manage audio-video and other types of network profiles remotely using a standard web browser.
    To learn more about the specifications of the M4250 series switches, kindly check its data sheet here.
    DaneA
    NETGEAR Community Team
  • Hi,
    i guess you got me wrong. I was asking for a user management to manage the switches. For example:
    Admin - full access
    Advanced User - e.g. configure VLans
    Basic User - Assign Ports to given VLans only
    Guest - View only
  • DaneA's avatar
    DaneA
    classicsound,
    My bad! 😞  I apologize for getting it wrong.
    Still, thank you for your response. 🙂  Be reminded that the more kudos given by community members to this feature request will help as the development team will be reviewing the post that has the most kudos and might get considered.
    DaneA
