Greetings all Recently i have got my home fiber internet bandwidth upgraded to 2,5Gbps. Being a fierce netgear fanboy i started to look for an upgrade for my existing Netgear Nighthawk Router. ...
Oct 10, 2022Guru - Experienced User
So you can buy just the router part on its own for cheaper.
Or you could go with something like the CAX80 thats has a 2.5gig output port (if you're on a cable modem system)
I'd agree that the RAX200/RAXE500 should have had more than 1 multigig ports so you can have 1 for wan and 1 for lan.
