Can you enable more advanced setting options via the webgui on the RBR753S like you do on the other Orbi Models? Like diable SSID broadcast, MIMO, etc?
JoshHen
Jan 22, 2021Guide
I'd also like to request the following:
Ability to set via DHCP lease time via GUI
Ability to change the admin username (Major Security Hole)
Ability to enable and disable Guests from seeing each other on the network
Also, The ability to configure:
Beamforming, MIMO, FastRoaming & Daisy Chain
Basically, I'm requesting Advanced Settings in Advanced Settings.
Right now, it's more like an Apple product (no offense to Apple) and I really need to tweak it for my use like I've done on the other Orbi and Nighthawk routers.
