Can you enable more advanced setting options via the webgui on the RBR753S like you do on the other Orbi Models? Like diable SSID broadcast, MIMO, etc?
logan989
Feb 09, 2021Novice
I've been racking my brain thinking I missed something when searching for SSID broadcast disable, but further research here indicates that this is a flaw in Orbi's approach. I like that I can hid the guest network, but would like to hide my entire network from visibility. Yes, I know hackers can see still the network with tools, but for the average user, it keeps the network hidden from snooping. You can't connect to something if it's not "visible".
