Can you enable more advanced setting options via the webgui on the RBR753S like you do on the other Orbi Models? Like diable SSID broadcast, MIMO, etc?
MTeam
Mar 12, 2021Novice
Agreed. Having a hidden SSID is an added level of security for a WiFi network even if one uses a strong password. It is harder to break into a door you cannot see.
