kevin009
Oct 06, 2020Star
Status:
New Idea
Ability to force devices to 2.4Ghz or disable 5Ghz band temporarily
I purchased an Orbi router and I'm not able to use my phone to configure my devices that only support 2.4Ghz (alarm clock, security cameras). A lot of devices require your phone to be on the 2.4 band and then use their setup app to connect to the network. It's disappointing to see a router this expensive missing a feature like this. The firmware is very basic.
Also, the support through the app is not that great. I connected to Meraj A and he would just bounce me back to the queue when they couldn't find an answer for me (I didn't know that they could do that when they just didn't want to deal with someone). Alfredo C was eager to help and was much more knowlegable than Meraj, but his only solution was to find another router and connect it to the orbi for 2.4 devices. This doesn't say much for a product when you have to connect a cheap router to get the features that the orbi is missing. SMH.
4 Comments
Comments have been turned off for this idea
What many end up doing is turn down the broadcast power of the 5ghz and disables its 5ghz ssid. this doesn't stop the actual broadcast. but if you disconnect your phone and reconnect it, many times you end up connected to the 2.4ghz and can setup your devices.
Yeah, I read that comment somewhere else and the lowest I can get the power down to is 25% and it doesn't appear to be enough for my phone to bump over to the 2.4 band.
- stogdanFollower
I have some IoT devices running on 2GHz only, and was tipped to turn down the broadcast power for 5 Ghz. However it did not help for me, and I had to use another router with 5GHz disabled to set it up. Dissapointing that products with this price tag does not offer this simple ability, even for a short time of connectivity.
- JCasettaTutor
I had the same situation and I had one of the gurus help me. The title was Split Wifi Networks for the Orbi AX6000
I am cutting and pasting the answer below they gave me that assisted and worked with my 2.4 devices which consisted of a Refrigerator, Washer & Dryer, GE Hood, Dishwasher, Ceiling fan and other various wifi gadgets.
The problem you're having may not have to do at all with 2.4Ghz vs. 5Ghz because your 2.4Ghz devices do not support and cannot see the 5Ghz network at all. Instead, there may ne other factors affecting the wireless compatibility of your new Orbi AX system with your wifi enabled appliances. Let's first try these changes:
- In the latest V3.2.16.6_1.4.4 firmware in orbilogin.com Advanced... Setup Wireless you can uncheck AX mode just for 2.4Ghz. In older firmware versions you could only uncheck AX mode for all bands.
- If that doesn't help, in Advanced... Advanced... Wireless Settings change CTS/RTS Threshold for 2.4Ghz and 5Ghz from 64 to 2347. I found this helped with AX 2.4Ghz wireless compatibility with many of my home devices in the older firmware versions, but it may not be necessary anymore with the latest firmware.
- Finally, another thing to try is in Advanced... Advanced... Wireless Settings you can temporarily change the Transmit Power Control for 5Ghz from 100% to 25%. Then setup your older wifi devices. Once they are setup you can restore the 5Ghz power back to 100%.
One other factor is that often these devices are setup using an app on your phone. This can be problemmatic if your phone is connected to Orbi's 5Ghz wireless network and you select that in the app for your 2.4Ghz device (so it will not work). Depending on how the app works internally, if the app offers an alternative method for selecting the wireless network (like typing the SSID in) then try that vs. using the networks seen on your phone. Unfortunately your phone sees the 5Ghz network but your devices need the 2.4Ghz network.
