Walkabout2017's avatar
Dec 14, 2017
Status:
New Idea
Add Circle by Disney to the R8000P AC4000 router
Would like to see the R8000P router (AC4000) add Circle by Disney... the website already says it does but it does not.
Also would like to see these forms add this same router to the "Model" field above since only the R8000 is there currently!
2 Comments
Comments have been turned off for this idea
  • well i have the r8000 and circle works with it but the darn thing is so unuser friendly, its driving me crazy getting it set up! ugh. not sure what the difference is between the r8000p and the r8000, try chatting with netgear support. maybe you can get a quicker answer.
  • The difference between these models at least the biggest is the Speeds . I believe the  R8000 is AC3200 and the R8000P is AC4000.  I wanted the faster model as I already have one with AC3200 and don't want a duplicate just to add the Circle functionality.   Thanks for the info about usability that is good to know.
