Please add Circle to the R9000 Nighthawk X10 AD7200 Quad-Stream Wireless Router. I selected the R9000 because it had enough hardwired ports to connect to my existing wired network and the 2Gbps port...
michaelkenward
Apr 15, 2018Guru - Experienced User
For anyone wanting to check their hardware go here:
What NETGEAR routers support Circle with Disney? | Answer | NETGEAR Support
It isn't obvious from there that the R9000 ever supported Circle with Disney.
The best way to get more ports is to choose a router that has the features you want and then to buy an inexpensive switch.
Home/Office Ethernet Switches | Switches | Networking | Home | NETGEAR
