Please add Circle to the R9000 Nighthawk X10 AD7200 Quad-Stream Wireless Router. I selected the R9000 because it had enough hardwired ports to connect to my existing wired network and the 2Gbps port...
Sprintst3000
Nov 05, 2018Fledgling
tbh999 wrote:
Please add Circle to the R9000 Nighthawk X10 AD7200 Quad-Stream Wireless Router. I selected the R9000 because it had enough hardwired ports to connect to my existing wired network and the 2Gbps port agregation was a bonus for connecting to my Netgear ReadyNAS. However, for some reason NetGear has decided to abandon those who purchased their flagship Nighthawk router and are offering Circle only on there less expensive models. Also, just to add some confusion, if you go to the R9000 product page, there are references to Circle on the page under parental controls!
I bought the R9000 as I thought it had circle on it.. if you look at the advertisement it's not clear at all .. so why not add it and if so when...
Not happy
