Please add Circle to the R9000 Nighthawk X10 AD7200 Quad-Stream Wireless Router. I selected the R9000 because it had enough hardwired ports to connect to my existing wired network and the 2Gbps port...
KimMC
Jan 09, 2019Novice
I have the latest firmware (V1.0.4.12) and it's definitely still not there. I also tried to see if I could add a Circle device separate from the router, but on the Circle website it appears the Circle device needs to have compatibility with the router and r9000 is not listed as compatible. Also looking to know when ths will be added to the r9000 router! Thanks.
