Please add Circle to the R9000 Nighthawk X10 AD7200 Quad-Stream Wireless Router. I selected the R9000 because it had enough hardwired ports to connect to my existing wired network and the 2Gbps port...
Mhall98
Jan 29, 2019Follower
The nighthawk x10 is supposed to be the best but it’s like netgear just gave up on it! The older netgear routers support stuff that the x10 doesn’t! You would think a newer router would support more but this is not the case here. Definitely Not worth the $!!
