I am not sure how this is still NOT a fearure... Under Advanced>Security>Schedule, we should be able to setup multiple schedules for and it should even be per device. Currently, I can set only one sc...
CasperTheDog
May 20, 2018Aspirant
I agree, this is something that is needed desparately. I have a part workaround. My kids phones (and mine) don't do 5G so I apply multiple schedules using the wireless options. The 2.4 wireless (which the phones use) is set up to operate at various times on different days. The same can be done for the 5G wireless, which is where the family laptops are. Then I put some of the kids laptops into an IP group to apply the firewall schedule to. This allows a bit more flexibility but still restricts you to having to put devices into groups rather than individual schedules which would be better.
