Routerer's avatar
Routerer
Status:
Unspecified
Add option to disable/dim Netgear logo
This was also posted here https://community.netgear.com/t5/R6000-Series-AC-WiFi-Routers/Feature-request/m-p/1063674#M11668.
Please add support to disable the NETGEAR logo on the router. I have no option for relocation and the light is too strong at night. I dont want to use tape because that ruins the router finish. At the moment I am just covering with a cleaning cloth. Please - this is XXI century. Option to turn off the logo (bonus if it can be done on a schedule) should be a no-brainer.
Thanks for the support
3 Comments
Comments have been turned off for this idea
  • P.S. My router model is Netgear R6250, on latest firmware (V1.0.4.2_10.1.10)
  • I have the same issue. It really should be possible to run off the led logo. Other Netgear routers offer this functionality (e.g. EX7000, Nighthawk). Please update the firmware accordingly.
  • There is nothing wrong with the logo per se - it is really sleek... BUT NOT AT NIGHT. So - allow us the option to turn off and back on based on schedule in a future update. Thanks!
