bebbo
Jan 14, 2016Star
Status:
Resolved
Add VPN TUN Option to the D7000 to allow connection from iOS and Android devices
Please could you consider adding the TUN profile in the OpenVPN server software already installed on the D7000 router to enable access from iOS and Android devices. From using the OpenVPN Server ...
BMG
Jul 15, 2016Aspirant
bebbo wrote:Please could you consider adding the TUN profile in the OpenVPN server software already installed on the D7000 router to enable access from iOS and Android devices.
From using the OpenVPN Server myself, it should be a reasonably straight forward configuration issue as opposed to additional firmware.
If you cannot provide this then would you at least allow the VPN ports (4500 etc) to be freed up when not in use so I can forward them to the internal network. At present these ports are blocked from being set for forwarding to the internal network irrespective of whether the VPN server is active or not...
Thanks
Hi bebbo,
Totally agree with you comments regarding VPN ports 4500, 500 etc to allow L2TP tunnelling to be used from another connected VPN device such as a billion 7800vdox modem that is connected to my d7000 via the billion's wan port.
