UKSentinel
Jul 18, 2017Aspirant
Status:
Unspecified
Allow Modem UI Access from behind an NightHawk Router via WAN Port
I own the R7800 and works well, I am connected to a Draytek 130 modem via WAN port and I would like Netgear to add the option to allow UI access to modems from behind...
TheEther
Sep 08, 2017Guru
This feature is unnecessary. By default, routers will send all non-local traffic towards the modem. Most modems are reachable through their own private address. So long as that address doesn't conflict with the router's subnet, you should be able to connect to it from behind the router.
