I have an Orbi RBR350 (https://www.netgear.com/support/product/rbr350) but I assume this will apply to others as well. I can set the DNS server to our local DNS server but I cannot set the sear...
Apr 11, 2023Guru - Experienced User
If it's given to you by the ISP, some ISP do there own FW development using NG HW, Thus NG doesn't develop the FW used with ISP developed HW. Something to contact the ISP about. I also have a dozen clients on my network. Have never had the need for DNS search domain requirements or processes. All works as expected and designed. If you need that feature, something to check with Pro versions then.
