Please add in a feature to disable SSID broadcast on the Orbi Tri-band RBR850. The stated reason of "you don't need it" is clearly contradicted by the number of people who have been asking for it, a...
michaelkenward
May 13, 2021Guru - Experienced User
jerryrice420 should look at what AP mode means.
It disables many features that you see in a router. That's because they have act as a router.
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
Nothing to do with firmware changes or SSIDs, the subject of this suggestion.
It is up to your router to handle Access Control.
