Please add in a feature to disable SSID broadcast on the Orbi Tri-band RBR850. The stated reason of "you don't need it" is clearly contradicted by the number of people who have been asking for it, a...
Jan 26, 2023Guru - Experienced User
Hide SSIDs isn't supported on MESH systems since they have to be seen by the satellites to work right. Also hiding SSIDs isn't really working. Hidden SSIDs can still be easily found with any wifi scanner.
