I beleive it would be extremly helpful to allow ORBI owners the ability to change power levels on satellites by frequency, e.g., 2.4 gHz and 5 gHz. This option may help some owners to eliminate cros...
mun_96
Apr 08, 2020Guide
This can be done. If you go to advanced settings and from their into wireless settings, you can adjust the power transmission for each band.
