It would be interresting to be able to download the APK file instead of beeing watched by Google. Like the old way!!!
harie
Sep 14, 2025Aspirant
Hi! I totally get the issue—on a 4K display, Genie’s interface text can be really tiny.
Unfortunately, if Genie doesn’t offer built-in font scaling or UI zoom settings, your best bet is to adjust your system display scaling. Here’s how:
- Windows: Go to Display Settings → Scale and layout → increase scaling to 150% or 200%.
- macOS: Go to System Settings → Displays → choose Scaled and select a more readable resolution.
If Genie is a browser-based tool, try using Ctrl + or Cmd + to zoom in.
Also, consider reaching out to the Genie support team—this seems like something they should support natively for high-DPI screens.
Hope that helps!
