Hi,
Create in the Advanced Menu a ARP Configuration (parameters), that let permite permanent IP+Mac assigned to table
A iptable FW tha allow to control better the in/outbound connections.
WiFi device access control that allow/block devices on the WiFi-side to access the management router
To Guest Wifi define a diferent Dhcp-Pool in subnet
In VPN Service add route-GW config, is missing in OpenVPN client setup.
thank you
1 Comment
Comments have been turned off for this idea
- vulkanusFollowerAlso, ADD a configure a session timeout for the web interface, it´s to short, keeping put admin PW.
