AlexGerwer
Sep 01, 2021Aspirant
Status:
New Idea
Assure interoperabliity between legacy WiFi devices and an Orbi WiFi 6 Network
Given the idiosyncrasies among various WiFi devices, even those that are common place, I would suggest that Netgear produce an adapter "box" which could be attached to legacy devices via USB and coul...
Sep 02, 2021Guru - Experienced User
You could use an old router and set it up as a bridge or in access point mode.
In bridge mode, you could hardwire in your printer/devices.
In access point mode, your legacy devices could connect to the older wireless standard while newer devices could connect to the Orbi AX.
