They should make an auto update option with the ability to set the time of the update. Also when doing a Firmware updates all the custom names and devise types that have been set are lost. Very fru...
2lundbergs
Nov 14, 2022Fledgling
R700P router with latest firmware update: I have noticed the following issue with the address reservation table. There seems to be no way to delete entries (i.e. free up reserved entries for MACs that are no longer valid). You can add and edit, but if you want to "reuse" the reserved ip you can't. I recently changed to a new computer and the old system still has its reserved ip. Could the next firmware revision please be more able to delete entries from the address reservation table? There doesn't appear any way to communicate this to NetGear directly.
Alternatively,if someone has been able to successfully do it, let me know how!
Thank you
