They should make an auto update option with the ability to set the time of the update. Also when doing a Firmware updates all the custom names and devise types that have been set are lost. Very fru...
Nov 14, 2022Guru - Experienced User
You might post here about this:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
There is not R700P router. Do you mean the R7000P router?
