KermitFrog's avatar
KermitFrog
Follower
May 04, 2022
Status:
New Idea
Auto re enable device access
When I disconnect a device from the network via the Orbi app (childs device in this case), I would like it to re-enable after x hrs. Or allow me to specify which hrs are allowed.
A bug with the existing app is you can’t remove a block on a device unless that device is turned on. i.e. It doesn’t show up in the list, so you can flick the switch to ‘on’.
Comments have been turned off for this idea
