s_rosenthaler
Jan 24, 2017Follower
Status:
Resolved
Automatic firmware update for home routers / Antivirus integration
Please integrate an automatic firmware update feature for routeres that are focused on consumers. A lot of users still don't care about security. If this would be done automaticly it would increase the overall security of your customers home networks.
Also an Antivirus / package filter integration on network level to proctect IoT devices would be nice to see in the near future.
7 Comments
Comments have been turned off for this idea
- MrRavNovice
Yes, please create an option to update the firmware automatically. Thank you.
- AbhayBNETGEAR Employee RetiredStatus changed:UnspecifiedtoEngineering Investigation
- AbhayBNETGEAR Employee RetiredStatus changed:Engineering InvestigationtoResolved
Done for most routers. Others will get firmware update to turn this feature on in short time.
Victor008 unlikley - as the authority for updating firmware on cable modems and routers is with the ISP.
Don't know if the list of applicable devices is current - here the KB entry on How do I enable/disable auto firmware update? - michaelkenwardGuru - Experienced User
Indeed.
If your firmware is outdated, you cannot manually upgrade your cable modem’s or modem router’s firmware. You must contact your Internet service provider (ISP) to upgrade your firmware.
- Victor008Aspirant
Thank you!
